Noted 🌞🌈chit-chat is over there![]()
Well that's a bit far fetched and you know it.Oil leaks that aren't fixed means no oil in engine.
Have you seen some of these new Jeep owners? Nothing surprises me.Well that's a bit far fetched and you know it.
Crazy, I know! I have been using the OEM brand of OAT that the manual recommends. (See below) You bring up a good point though as I heard Jeep changed mid year to this from the HOAT so I wonder if the shop is refilling with the wrong stuff.Two in a row could be bad luck, but four 🤯
What coolant do you use?
Mixing HOAT with OAT shouldn't crack radiators I think. it causes coagulation and blocks the flow, but that should be it. I was thinking maybe there is something corrosive in the system, but seems unlikely. Are the radiator mounts ok? Perhaps the radiator is being pinched / twisted / stretched?Crazy, I know! I have been using the OEM brand of OAT that the manual recommends. (See below) You bring up a good point though as I heard Jeep changed mid year to this from the HOAT so I wonder if the shop is refilling with the wrong stuff.
Your response makes sense on the mixing of coolant types. I wondered about the mounts as well as it does seem feasible there is excessive vibration and movement that could be causing the tank seal to leak. I gave the repair shop an earful on my last replacement since they are charging me for some of the labor. I would expect they would be know to ensure that is mounted properly given the number of replacements. Perhaps I assume too much! Thanks for the response!Mixing HOAT with OAT shouldn't crack radiators I think. it causes coagulation and blocks the flow, but that should be it. I was thinking maybe there is something corrosive in the system, but seems unlikely. Are the radiator mounts ok? Perhaps the radiator is being pinched / twisted / stretched?
They tend to seperate at the plastic "weld" to the metal on the majority of the failures. I blew one up running too straight a water mixture. The pressure from the steam just took out the whole upper left corner-I still have the original 2013 OEM Radiator in mine. never had a leak or issues with it. Do yours all leak in the same area?
Exactly what happened to mine, OEM one failed last year.They tend to seperate at the plastic "weld" to the metal on the majority of the failures.
