First of all...to be clear, I caused this problem. It is not a factory defect or anything, but I need to figure out what happened. The side mkr/ turn signal lights are not operating at all. While ago, I cut these wires and lengthened them to relocate the lights to a pair of homemade fender flares. After I stripped the wires to prepare for soldering in the xtra length of wire, the wires (the pos & neg wires on both drive and pass sides) touched together briefly. Batt was still connected as I didn't mean for them to touch. I soldered in the xtra length of pos and neg wire (only several inches worth) and hooked the lights up again...and nothing (?). I changed out the bulbs to make sure they weren't blown or burned out...and they are fine. I looked in the owners manual thinking maybe it was a fuse. Checked several fuses but am not sure if I looked at correct fuses, as there was nothing I could find designating specific side mkr or turn signal fuses. So a buddy of mine thinks that the computer needs to be reflashed or something like that...Is this true? Did I possibly overlook a fuse? I hate going to the dealership and asking them to do something that might be able to be done myself...Any suggestions would be appreciated. BTW...The front grill turn signals still work.
