1 - 8 of 8 Posts
Hey guys,
I am at work right now and just had a quick question...
For those that have cut their ABS lines. What type/gauge/etc is the wire running to the wheel?
I plan on choppin and extending those and just needed to know what to pick up on the way home.
Thanks! :beer:
I can't recall what I used, but it was 18, 20 or 22, the factory wires are real thin, especially at the front.
Thanks Phil,
I will probably just pick up some 18 gauge then. Was it just standard multistrand wire?
I am surprised, I did not realize they were so thin. really makes you realize how easy they could break :eek:
It's just two wires for each, the front is a bit of a pain as it is encased in rubber, the rear is just two wires twisted together.
FWIW I extended mine by about 8" and they are plenty long enough. I also did all the locker wiring.
Hey Scott, pm me your address if you want, I have some really good 2 conductor cable in a nice thick rubber jacket. I think it's 18 or 20 gauge stranded. It came off our real time x-ray machine, it's designed to flex all day long and not break. I'll send you what you need.
Sweet!
Thanks John!
Just need enough for the front and rear.
oh...Hey, I told Airric00 that when I picked up wire and connectors I would pick up enough for him as well. Do you have that much extra?
I would be happy to send you some $$$ ...If you don't, no worries
PM sent
Sweet!
Thanks John!
PM sent
I have plenty, 1 piece at 33.5 feet, 1 piece at 12 feet, and 1 piece at 11 feet. Just let me know how much you guys need and I'll send it, no charge. I'm a pack rat, it'll just sit here and take up room:)
BTW, it's 20 gauge.
The cable is Iges Chainflex CF130-05-02, here's the tech sheet on it. Both of the insulator jackets are black, but they are numbered "1" and "2".
See pics below.
Oh, and your pm didn't get through.....
1 - 8 of 8 Posts
