The stock LCA mounts hang below the axle a bit, which makes them vulnerable to catching rocks. I realize I can get skids for them, but I was thinking... is there a way to just move them higher so they're out of the way? It seems like it should be possible to fabricate LCA brackets that go directly behind the axle tube so they don't protrude from the bottom and catch things.
This would also move the LCAs up a little higher, and angle them so that they sit closer to parallel with the ground... maybe eliminating the need for control arm drop brackets.
I did a quick Google search on this and I found some people who have done it before on other vehicles. Has anyone tried this with a JK? Is there any reason it wouldn't work?
