OK guys, put on the new shocks today that came with the lift that I didn't put on two weeks ago due to a batch of bad bushings...
While I was under there and working on the Jeep, took some pics of the driveshafts. I have been worried about pinion angle since I did the lift. PhilD has been extremely helpful as I have been communicating with him repeatedly via email. However, he has a business to run, and I do not want to take advantage of him unduly. I have been thinking about going with the Reel 1310 O.E. driveshafts for my JK since I did the lift. However, when I first did it, I would say I got closer to three inches, maybe a bit more, now, I have between 2" and 2.5" since it has settled. I am not even sure I need shafts now. The boots and shafts look great. I have pics. Problem is, I do not really know what I am looking at. Phil wanted me to check the pinion to see if it were less than 5 or 6 degrees so I would not have to purchase control arms, cause I can't afford that at all, but it was actually less than that. Here are the pics:
Front pinion angle of driveshaft-
and here is the rear shaft and pictures of angles and what not....
The readings I got using the level and diagram suggested by PhilD are as follows: and they vary depending on where I put the level on the driveshaft
Front-3.9-4.6 degrees, with 2.6 closest to the transfer case
Rear-3.9-4.7 degrees
Those pinion angles are lower than I expected for some reason, even though its a 2" lift. Its also a two-door. I think Phil and I have determined that the 1310 OE will be fine for me if I replace shafts, but I am wondering if I even need to, or if I can get away with running these things.
I do plan on putting 33s on there when I can afford them, rather than the 32s that are on there now.
So what do you guys think, and Phil feel free to chime in, I just didn't want to be wearing out your email at work?
Thanks.
Thanks.
