1 - 10 of 10 Posts
I buying new Mickey Thompson Baja MTZ LT31570R17's and was curious what ppl run for psi for dd?
I'm running 27psi in my 37/13.50/17 toyo m/t's
You can use what others run as a general guideline, but to find out the best tire pressure for YOUR rig you'll want to do the chalk test.
How to chalk test
running 35's with 33 psi. I know its not 37's but that seam to work for me much better ride than running em with say 35 psi.
I run 30 psi, in my 35" Procomp AT's, with good results
Doing the math using weight and tire specs (load & pressure ratings), I'd be at 20 psi. I run the trails at 18-20 psi. No way on the street. Using that math assumes increases in pressure and loads are linear. Perhaps they're not.
1 - 10 of 10 Posts
