Ok folks, I'm gonna be Debbie Downer here so bear with and let me first say that for bolt on products PSC really does make some very nice shit that not only looks great, but functions well also. Larry and his crew are top notch and they really strive to be at the top in their industry.
Now with that said let me give a few words of advice regarding tub mounted sliders. First off, by design they are a very, very bad idea for anyone looking to wheel their shit in any manner remotely considered "hardcore".
Brawler Rockers are sweet as far as providing a perfect step and for gently sliding around in the rocks with the key word being " gently"! They are also the single best looking tub mounted slider on the market as far as I'm concerned however they are plagued by the inherent problems associated with tub mounted sliders.
With the way they bolt to an already very weak, long ass tub section, the cantilever of the step leaves the tub side susceptible to tons of damage should you find yourself crashing down, around and through big boulders or if you push up and over shelves where the break over points are just too much and the full weight of the jeep comes crashing against it. The tub WILL taco and you will discover that your doors either no longer fit or fit very poorly. Many of us have gone through this experience to come to these conclusions and have first hand learned the hard way.
The Rocker Knockers, while not providing much of a step, don't mount directly to the side of the tub but rather under the tub so as far as keeping tub side damage to a minimum they are excellent in that department but mount roughly 1/4" below the bottom of the door so if you come down on them really hard they can bend upward and keep the door from opening and closing. It is this problem that makes these sliders not a good choice again for hardcore wheeling. They also have a shit ton of flex that you can see when you put the weight of the jeep on them and start swinging around boulders and they can get ever so slightly into the tub but you have to be all up in the shit to push them that far. Having tub armor in that case is a very good idea.
Don't despair though cause PSC has another slider that works great. A couple years ago Larry and I went through some issues I had with my Brawler Rockers and wound up designing frame mounted, bolt/weld on rocker knocker style sliders. They are almost identical to the Rocker Knockers only they mount to the frame and have no attachments to the tub whatsoever. I have the first set we came up with and now they are on a buddies jeep taking all sorts of abuse without fail. The step is minimal but the compromise is well worth the lack of damage you will get if you go tub mounted.
I could spew on and on about tub mounted v/s frame mounted but bottom line is do it once, get frame mounted sliders and don't look back...
