1 - 10 of 10 Posts
I am stepping up to an LS swap so I am looking to move my prodigy turbo kit. The basic details can be seen here....
https://prodigyperformance.com/products/pro-1002-stage-2-turbo-kit-for-2007-2011-3-8l-jeep-wrangler-with-intercooler.html
This kit is for the automatic trans, It is a garrett turbo, non polished, IS the ceramic ball bearing turbo. This is a really nice turbo just by itself.
Additionally.... I had all of the turbo piping ceramic coated as soon as I got it so help with heat and to prevent corrosion. I added the titanium hot side turbo blanket (cost $179 by itself).
Also I am throwing in all of these listed components along with this sale, All of these components were installed new at the same time as the turbo kit and have the exact same mileage which is slightly under 1k miles.
OEM radiator
OEM radiator cap
mishimoto 180 t-stat
OEM T-stat housing (still new in the package as I bought 2 on accident)
OEM plug wires
OEM o2 sensors (all 4)
OEM upper and lower radiator hoses
Screamin Demon ignition coil
gates belt
OEM tensioner
If you live close enough I will swap core supports with you to save you some work on the install as mine is setup and ready to go.
Just the kit with the turbo blanket is over $6700 new.
I am asking 4k for all of it including all the extras that probably need to be freshened up anyways on most jeeps with a 3.8
The engine and trans can be had for an additional $500 both are very sound and I did a compression check prior to this install and it was perfect. All of this is still in the vehicle so if you are close enough you can come check it out in person. I don't daily drive the jeep and it is limited to showings of the turbo until someone wants to buy it. It is all in just about perfect shape with zero issues. You are welcome to see this in person.
I blacked just the visible faces of the inter cooler with a light coat of heat dissipating radiator paint. Black is shown to draw more heat out anyways. Either way its just on the surface though and not all the way through the core.
trades welcome! looking for nice front axle, guns, 4 wheeler, nice tool box, etc....
I am in the DFW area of TX. I never had it dynoed but the butt dyno was very impressed. Makes just driving around so much easier and being able to scoot down the hwy and actually pass if you want to is nice.
Sent from my SM-N920T using Tapatalk
1 - 10 of 10 Posts
