1 - 11 of 11 Posts
So I put a couple of LED lights in my dome light (pictured below), and a weird thing's happening. If they're turned on with the steering column switch, the lights work fine, but if I use the push-button switch on the dome light housing, they go into a strobe mode, and start flashing. Another thing, they only strobe with the ignition OFF, if I turn it to ACC, it stops the flashing. Does someone know what causes this phenomenon?
On a side note, these lights are 10X better than the stock bulbs.
my guess is more wonderful canbus pulse width modulation
might try either a resistor to mimic a regular bulb or a capacitor to 'carry' it over between pulses
If the stock lights worked, how are these 'better'? :laughing:
Sounds like a lot of work. Perhaps I could incorporate one in the footwell lights I'm planning on doing and link it in that way. Thanks the reply.
They only strobe if the dome-light switch is used with the ignition OFF, otherwise they work OK :shaking:
My advise to you is use the inline resistor or put the lights that aren't as expensive or glamorous, but work ALL the time back in. :laughing:
Not sure where you got the LED's, but my recommendation is go to http://www.oznium.com/ and order their dome lights. I have them in for a few months now, and the work great in all "modes" to turn the lights on. And install couldnt be simpler. Oznium has great products....if its an LED, they carry it.
I agree, got all my leds from Oznium
Got the ones pictured above at superbrightleds.com. Don't really feel like spending any more money on LEDS (yet), I'll just live with what I got.
The domelight is now way brighter than it was with the incandescent bulbs (114 lumens vs. 20 lumens), and it's a very clear white light. It works when I need it, which isn't very often, so that's good enough for now.
The replies/suggestions are much appreciated ~ Thanks JM
I say trash them and put the OEM bulbs back in. The mods we do on our Jeeps are supposed to make our lives better and easier, right?
1 - 11 of 11 Posts
