1 - 8 of 8 Posts
I did some searches on here and didn't see anyone with the same issue. This summer I've taken the doors off my Unlimited Rubicon a few times. After the first time I noticed my driver's door window switch on the dash was no longer lit. Figured it was just a bulb out. Took my doors off for a good week recently and then when the doors went back on, ONLY the driver's door window switch is lit.
I also noticed the auto-door locking feature isn't happening now. I know you can set this with a sequence, but I didn't do the sequence to turn it off.
Any ideas?
Make sure your connections & connectors are perfectly connected, and, red latch is closed to keep them together. Sometimes, when the plugs are reconnected, the pins inside the connectors get shifted, not perfectly connected.
The window switches are supposed to light up? :confused:
all four of mine are out. died at various points. I cant see it being a blub, more of an LED? No ideas though. Let us know if you figure it out.
Does anyone have them all working still?;)
I had assumed it was just the one that went out until the second time I put the doors back on when it became the only one to be lit now. I haven't tried to figure it out, as it isn't a huge deal.
1 - 8 of 8 Posts
