1 - 17 of 17 Posts
I have a few tool questions for you guys. In regards to corded electric tools what should you look for when buying a good corded power tool?
I am looking at buying a 4.5 Angle Grinder/ cut off wheel. What should I look for (amps/rpms?) (higher amps/rpms the better?) Anything else? Also are there any tools that are made in the US; I was browsing at Lowes and every single one of their power tools is made elsewhere?
Any tips on buying any good electric tool would be helpful.
Thanks for your help guys.
Look up Wylaco. He is a vendor on here that goes by aplumber.
He sells dewalt stuff for awesome prices.
More specific to your question, any good 4 1/2 inch grinder will do the trick for you. I have a few cheap Harbor Freight ones that work well but bog down fairly easily but they were like 15 bucks. Then I have 2 Dewalt ones with the paddle style switch that are super awesome.
I looked on Lowes website just now and didn't see a 2fer promotion. Maybe all the stores aren't doing it? Sounds like a good deal.
Here is the Wylaco Dewalt special. It's hard to beat the price with the wheels and such. And 13 amps at 11k rpm. More power! Argh argh argh argh (Tim Allen voice)
http://www.wylaco.com/bargain-basement/DEWALT-4-1-2-inch-High-Performance-Grinder-Special-Promo
Edit: Amazon has a good deal on Dewalt grinders too.
http://www.amazon.com/DEWALT-D28402K-2-Inch-Small-Angle-Grinder/dp/B000BM6BMI/ref=sr_1_2?ie=UTF8&qid=1329199955&sr=8-2
To be fair though, the above is the 10 amp model.
The same one that Wylaco is selling is about 12 bucks more without the wheels on Amazon.
http://www.amazon.com/DEWALT-D28114-2-Inch-High-Performance-Grinder/dp/B000HI0ZZA/ref=sr_1_5?ie=UTF8&qid=1329199955&sr=8-5
I've got a Hitachi angle grinder that I picked up from Lowe's a few years back. It has served me well!
You will be hard pressed to find US made power tools anymore.
sent via smoke signal
I probably caught the tail end of the deal, they only had a couple left.
Useless information but something I really looked at was the button for the grinder. I ended up with a cheap ($30) Porter Cable from Lowes. I found most other low end grinders have a on/off button that is usually not in a easy place to access with one hand.
I prefer a click-button on the handle, seems safer to me. If something goes screwy, I want to know that if my hand slips...the damn thing will turn off!
+ Lowes has 2 Porter Cable grinders for $50 or something, wish I had gone that route. It'd be nice to have a grinding wheel/wire wheel/cutting disc on one with a flapper or something on the other...
Goody has a good point. As stated earlier, I have a few HF units with switches on top. They are kind of a pain to use. Not to mention if I happen to drop the grinder or something, it'll stay running.
I also have a couple Dewalts with the paddle switch. These are super easy to use and if something happened and it slips it will automatically switch off. Easier to use and safer!
Also mentioned, having at least two grinders is almost a need. One with a cutting wheel, and the other with a flap disc to clean up things sure is nice instead of swapping back and forth. There has been a few projects where I've had all four of my grinders out at the same time. Cutting wheels, wire wheels, and flap wheels of different grits. It's very nice just grabbing a different tool instead of swapping back and forth a million times. For most fab stuff though, a cut off wheel and a flap disc is almost always needed.
Discussion Starter #10
Well shit. I guess I should have checked here before I bought one. Just purchased a Dewalt with the paddle switch, one from Lowes. I would never settle for one with a on/off switch. It was either trigger or paddle for me; and the paddle seemed better.
I had never thought about wanting two, some good thinking. Well now I can either save for another or return this one and see if I can find a good 2fer.
My question about amps and RPM still stands (in regards to all/most power tools). I assume more amps and more rpm's would be a better tool, last longer?
Again, thanks for the input!
I wouldn't necessarily correlate the life of the tool with rpm/current ratings. Rather it is for what kind of work load it can handle. In my opinion.
Such as, using arbitrary numbers, a 10amp tool will handle and maintain speed (rpm) under load better than a 5amp tool. In other words, if you are leaning on a piece of steel while grinding on it, the 10amp won't really give a shit...whereas the 5amp will bog down and either quit...or you'll have to back off the tool.
I don't know about Porter Cable grinders, but all the Porter Cable tool's I own have suited me well for my occasional use and I would recommend them.
In general, I would suggest using craigslist or similar sites and buying used tools. There are so many barely used tools for sale that are good brands it's a no brainer. With the construction slump the past few years lots of contractors went belly up and liquidated their tools.
Edit: I just looked on craigslist as an example and found this one within 20 seconds local to me. I'm actually tempted to pick it up.
http://gainesville.craigslist.org/tls/2760641260.html
Discussion Starter #13
Alright. That what I figured. Just wanted to confirm.
But with that conclusion, my logic thinks this. That higher amprage would correlate with a longer life due to less stress being put on a tool. Obviously you should use each differently, but for examples sake, if you used both 5/10 on the same material as a control, the 10 would last longer?
And yes don't get me wrong. I know this question is probably way above and beyond an "everyman" using a grinder, but I wanted to understand what role rated amperage plays, when you are looking at the "stats sheet" at the store.
Thanks GGCuda!
Thanks GGCuda!
I really can't tell you for sure, I'd rather someone that actually knows answer that part (as far as the life expectancy goes).
However the comparison I am making in my head to that is like saying "a V8 will out last an I4 because it uses more fuel."...doesn't quite make sense.
There are a lot of variables to consider above The ratings you are considering. I own a decorative concrete company. We do a lot of concrete and rebar grinding. I like Dewalt tools for general duty, but for my work they are disposable. For a small grinder to survive our environment it has to handle heat build up and stay clean in a dusty environment.
I like makita's, especially this one: http://www.google.com/products/catalog?oe=UTF-8&hl=en&client=safari&q=makita+grinder&um=1&ie=UTF-8&tbm=shop&cid=2306074324493970498&sa=X&ei=oh07T8qbIsfz0gGHuv2fCw&ved=0CGwQ8wIwAg
However we mostly use specialized Hilti grinders. Go to their website and check out their selection. Their amp ratings may not impress, but they hold up to our extremely demanding requirements...... So they should handle anything you can throw at them.
Davesrb
I prefer a click-button on the handle, seems safer to me. If something goes screwy, I want to know that if my hand slips...the damn thing will turn off!+ Lowes has 2 Porter Cable grinders for $50 or something, wish I had gone that route. It'd be nice to have a grinding wheel/wire wheel/cutting disc on one with a flapper or something on the other...
Yeah you want something that if it comes out of your hand it cuts off. Mine cut my leg and then ran half way across the shop and was stil running.
Well I was working on my toyota the other night cutting out some metal to make motor mounts and this happened. :bawling:
I got in a hurry and wasn't paying enough attention and the grinder kicked back and caught my pants:shaking:. Just thought I would share my stupidity and maybe save somebody a trip to the hospital. I had to get close to 40 staples and some stitches on the inside to help hold it together.
1 - 17 of 17 Posts
