All my power outlets are dead whether the Jeep is running or not. I checked the fuses listed on the fuses box cover and they are all good. I also checked my tester just to be sure it was good and it was. I have used the outlets before and they all had power. Since I don't have a wiring diagram I have no idea where to check next. Any help to figure this out would be appreciated.
Can you elaborate on "all" your power outlets? Which ones specifically? Literally every cigarette lighter ports including the one in the rear of the Jeep? What about the 110V port? And the lighter port one inside the center console?
First let me make a correction it is a 2012 not 2013. The dead power outlets are in the dash and in the rear. I just checked the center console outlet and power inverter and both of those have power. Per the fuse box cover the fuses are good. What is strange to me is that both were working fine but both died at the same time.
Forgot to mention that I have not made any changes to the wire harnesses of the jeep. Just wish I could find a wiring diagram so I could run this issue down.
Well I got the dash power outlet working. Made a rookie mistake by just looking at the fuse rather than checking for continuity. So now I am down to the rear power outlet. This time around I checked the power and fuse with a meter and both checked out good.
Working now on creating an account to see if the web site above has the info I need.
