Metal Cloak Front Upper Shock Mount
http://www.metalcloak.com/6Pak-Front-Shock-Mount-Kit-JK-Wrangler-p/7021.htm
$79.00
Nemesis Front Lower Shock Relocater
http://www.nem-ind.com/catalog/jk/jk-suspension-parts/factory-dana-3044-front-lower-shock-mount
$89.00
Synergy Rear Long Travel Upper Shock Mount
http://www.synergysuspension.com/Sy...ar-Long-Travel-Upper-Shock-Mount-p-29226.html
$150.00
Fox 12" Travel 2.0" Smooth Body Emulsion Shock, 5/8" Shaft
http://www.polyperformance.com/shop/Fox-2.0-Smooth-Body-Emulsion-Shock-5-8-Shaft-p-639.html
$150.00 Ea.
Qty: 4 $600
Total: $918.00
Is this route more economical for the average wheeler looking to squeeze the most out of their suspension retaining stock mounts and not having to weld?
Wouldn't this get you the benefits like down travel and uptravel that a costly coilover system will run you?
you could run any type of shock to get you where you need to be depending on lift height.
$79.00
$89.00
$150.00
$150.00 Ea.
Qty: 4 $600
Total: $918.00
