I already have lower shock relocation brackets installed when I did the Rock Krawler Long Arm.
Getting more travel is the game plan considering the current set up maxed out the shocks that I had.
I already have lower shock relocation brackets installed when I did the Rock Krawler Long Arm.I don't have any experience with that bracket, but here is my opinion.
When using that bracket you should also use the lower relocation bracket. That should put your shocks back into a relatively stock-oriented position, so your ride quality shouldn't be affected much. On top of that, if you will be ordering new shocks, you would be able to run a longer shock and get more use out of your suspension.
That would be awesome. My exhaust is relocated as well so it isnt an issue.The shocks are a little less upright than stock. I don't see any undue pressure on the lower mount.
I'll post some pics when I get home.
Already had the lowers before all of this so the lower mounting position is fixed. We are just talking about the upper now and with long arms, the 10" travel shocks werent enough.But you are doing the lowers too right? then you are netting more or am I confused.
Yep limiting straps is part of the plan. I blew out both rear brake lines so new ones need to be ordered anyway. Didint think about the speed sensor lines.You will want to use limiting straps, even if you use spring retainers. With that down travel you may be pushing the limits of your brake line and ABS/speed sensor lines.
so the Bilstiens you are looking at have a compressed length of 18 and an extended length of 31? What model?
Your old shocks were 15 and 25?
So I got it up on a lift last night without any shocks in it, the distance between mounting locations for the shock is 26". This distance is fixed by the length of my tone ring wires and the length of my sway bar links.Which valving are you going with? Is 13" travel more than springs typically will handle before dropping out of the buckets in the rear?
Yeah its not super hard but the bracketry is ~$200 so the question is do I want to spend that and do the wires/sway bar links to get minimal gains.the speed sensor/tone ring wires can be extended pretty easily. It is just a regular wire. Cut, solder in an extension, button it back up....at least that what it looks like. I have not done the extension but I did cut open an old wire to check it out and it looked like a regular wire.
Right all my numbers were based on shaft movement, not exactly equal to wheel travel because of the angles.Your math may be off just a bit since the shocks are not vertical and your up and down travel will be different then the amount of shaft showing. And don't the upper brackets move the top mount farther away from the axle? Keep an eye on your pinion angle and u-joint bind as well at the new droop. You may need a limit strap at the differential as well.
Your axle does not move straight up and down either, it moves in an arc towards the center of the jeep as you droop it out. Tall short arm lifts will move quite a bit eating up shock travel with them in the stock mounting configuration.
Nope I am happy with the current set up. I just wanted to explore my options given the fact that I need to buy new shocks anyway.Were you unhappy with the way it was before?
If not just replace the shocks and make sure your bumpstops and limit straps are setup properly.
I have read a post from bilstein that says overextending a shock at slow speeds(rock crawling) should not damage the shock but it looks like at least one of yours got bent.
I have a very similar setup to you minus the long arms and the 10" travel 5160s work well with 2.5" coils.
So doing the math, after extending the lines and sway bar links, I can get 3" additional of droop minus limit strap reduction.A long arm 2.5" lift should have very little movement forward at the axle and if the mount moves up and back by those amounts you should be able to run a shock that has 2" more travel then what you have now while maintaing the same amount of up travel.
Extending the abs is as simple as just splicing in a new longer wire. If you don't want to worry about brake lines you can run them down one of the upper control arms and you will not have to worry about stretch. I did this as well as running the abs wire down the upper arm.
So a basic rebuild is $75 per shock plus shipping. I have bent shafts so that is an additional $30 per shock.What does bilstein charge to rebuild the 5160s?
I dont really have the skill set to do it and I banged up one shock body pretty bad so I dont think that one can be rebuilt.Why not rebuild yourself. It is pretty easy to do. The only special tool you will need is to get the ISP out if needed and you can make it out of all thread. Just buy the rebuild kits. I do my own king shocks. They are all pretty much the same.
