1 - 20 of 143 Posts
POLY PERFORMANCE JK 4130 CHROMO TIE ROD KIT GIVE-A-WAY------------------------------>
As the title says ladies and gentlemen. This give away is for a Poly Performance Jeep JK Heavy Duty Tie Rod Kit (Part # PPM-8002). Post up to enter the drawing. You must have a RED STAR to be eligible to win. The drawing will be held on Halloween.
-Heavy duty tie rod for Jeep JK Wranglers
-Bent similar to factory bar to clear sway bar mounts
-Made from 1 3/8" 4130 Chromoly and Heat Treated for maximum strength
-Poly Performance Double Adjuster Sleeve: allows adjustment of tie rod length without removing it from the vehicle
-Strongest Jeep JK Tie Rod on the market!
-Features an abrasive resistant powder coat finish for maximum durability and corrosion resistance
-100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
Tie Rod Kit Includes:
(2) Heavy Duty Tie Rod Ends
(2) Castle Nuts and Cotter Pins
(1) Heat-Treated Chromoly Tie Rod
(2) Grade 8 Pinch Bolts & Hardware
(2) Poly Performance Double Adjuster Sleeve
Material Comparison:
1026 DOM………………………….......80 ksi
7075-T6 AL……………………….......80 ksi
4130 Chromo…………………….......100 ksi
4130 Heat Treated Chromo…….150 ksi
Poly Performance Heat Treated Chromo Tie Rod is:
67% stronger than 4130 Chromo
90% stronger than 1026 DOM
90% stronger than 7075-T6 AL
So, all I have to do is post to this thread to enter? I'm game!! :bounce::bounce:
Sweet!!!...Throw name in the hat!!!:bounce:
:beer:
A nice upgrade to my freshly lifted Rubicon. Thanks for the chance to win!
Countt me in... if I win, that will be the VERY FIRST mod to my Rubi... well besides the cool license plate frame that gives my jeep about 50 extra horse power... :D
1 - 20 of 143 Posts
