1 - 14 of 14 Posts
Does anyone have the Poly lift ? The more I read up on it the more I like it ...:beer:
A little pricier than the others but I wonder if its worth it...
Any input on it would help ....
I say If im gonna do a lift Im just gonna do it right one time :smokin:
Daniel
You won't find any one that has one since we haven't shipped any yet, the kits will be shipping in 2 weeks. We sell all the component parts separately also. The key feature that sets ours apart from other kits (and adds to the cost) is that we use adjustable Johnny Joints and a left-right adjuster sleeve on all the arms and track bars. You do not have to take the arm off to adjust and there are no big jam nuts to try to tighten but always loosen up. It is very similer to the stock JK tie rod adjustment, just loosen a pinch bolt and turn the adjuster sleeve in or out. We designed a complete suspension system so everything works wells together, we have done extensive spring and shock tuning so the jeep work well on-road and off-road.
Post up and specific questions you have and I'll be happy to answer them for you.
I rode in Goats SWB JK in some dunes and for having a small wheelbase rides alot nicer than any TJ ive ridden in. especially once he had the Fox shocks dialed in. :smokin: Oh yeah that pic in petersons of it airborn is preety F*awesome :bounce:
irate4x4 dot com
Well, there are a lot of guys that use Poly to "build" their suspensions. Not just to order their parts but for advice when ordering as well. Guys that are building buggies, truggies or building up TJs, YJs, CJs and such seem to use Poly a lot
A
Guest
I’m planning on a Synergy III kit with Fox shocks when mine is delivered (about a month from now).
Thanks for your input guys...now I gotta work on the FINANCIAL MINISTER aka wife about the funds:bawling:
This kit seems to be just what I need !
What is the best shock option Poly can offer? Are you limited to the 2" body shocks on the JK or can you step up to 2.5" body shocks?
How about some air-bumps? Are you guys planning on offering anything?
The fox 2.0 remote reservoir with the compression adjuster is the best we currently offer. We are working on 2.5" shocks and air bumps. Air bumps are definitely useful but not always 2.5" shocks. There are clearance issues with 2.5" shocks, the advantage of a larger shock like a 2.5 is that they will last longer before they fade, but we have not had any problems with the 2.0's fading.
X2 The cheap Skyjacker shocks I had in between my Bilstein and Fox ones were 2.25" bodies and the fronts rubbed on the frame when the axle was drooped at either side. So far I haven't seen the same kind rubbing with the Fox 2.0's.
Our's do contact the frame, but only slightly, not enough to damage the shock or cause a problem. You can move the shock to the outside of the lower mount with a longer bolt and spacer.
For the PPM-8023-40 kit (2-Door Jeep JK Synergy Stage 3 Suspension System), the max tire size is 37". Is this with no other modification necessary? I'm looking to have quite a bit of extra weight thrown around once the winch and assorted armor pieces go on. Just want to see if I'm in for some fender trimming or a body lift to compensate.
I'm guessing you may have to trim the panel at the front of the rear well.
Obviously, as you had weight to different places around the vehicle, it will change things. I'd love to see someone offering front and rear springs from 4" to 6" in 1/2" increments.
1 - 14 of 14 Posts
