1 - 12 of 12 Posts
So has anyone pulled the shagalishous carpet from the JK yet and put a poly coat down??? Thinking about adding this to my to do list...:smokin:
Discussion Starter · #3 ·
I've been looking at some of the stuff that you put on yourself. Looks like there is a few quality companys out there if your willing to put in the time. I may go that way. I'll have to track down what I was looking at but they have lots of colors and textures. When I find it I'll put the info up. Heck it was about 100 dollars for a gallon that covers a 6 foot truck bed. Not cheep but cheeper than having someone do it.
In the XJ everybody uses the Herculiner http://www.herculiner.com/
It is realitivley cheap and very durable. Great DIY roll on stuff
I used a different brand, I forget what it was, it was off the shelf at a auto parts store. It was durable but in places that get rubbed a lot like on the floorboards under your feet it wore away. Also, some brands leave a chemical smell that you will smell whenever it is hot out.
I will be doing mine shortly with Herculiner. Only thing that could be any better is proffesional sprayed on liner...IMO
Duplicolor is what I used last time. For the most part it worked good except it wore off under my gas foot and under a tool box I kept in the rear. Otherwise pretty goos, like phil said, it is all in the prep. Take an extra few minutes to do a good job instead of throwing in the towel and it will last much longer.
Just curious, What kind of problms did you have Phil?
I had it in a pickup bed and it kind of dissolved. At first it went gray, but I wasn't worried about that, but then it seemed to be getting thinner and thinner, until almost just the texture was left. Not sure what the problem was, maybe the South Texas sun. I redid it with Duplicolor, which I've also used on numerous other things, and never had a problem.
Discussion Starter · #12 ·
What about the noise value? Does the poly coat deaden the road noise as well as the carpet???
1 - 12 of 12 Posts
