ok guys here's the question:would the poly per. trackbar brackets (fr+rr axle end)work with my tera 2.5in coil lift?
let me specify;I have the 2.5in specially design for the 2dr,so the amount of lift is actually 2-3/4 in the front,2-1/2 in the back,
now poly tells me the you should use a minimum of a 3in bump stop in the front to avoid the contact of the trackbar with the lower frame rail in the front
and a minimum of 2in bump stop in the back.
so does anyone have experience with this brackets touching the bottom of the
frame with a 2.5in lift?
and what about the drag link flip that goes with the front bracket,will
this touch the frame?
thanks everybody!
The Wheelin Man's Friend
They recommend it because it will hit the frame. You can start with 3" of bump stop, flex it, and remove as necessary.
They are compensating to ensure that you will NOT have issues after installing the parts. If you come out being able to use 2" of bump stop instead of 3 then that's a good thing.
I have a customer that I posted about in another thread similar to this one that is on a 2.5" Rock Krawler lift and he took 1" of bump stop out with the Poly hi-steer kit. He's got frame/axle brackets in the front and rear without any clearance issues.
Marcus
Discussion Starter · #3 ·
thank you marcus!
I have the teraflex bumpstop,front and rear,I think I'll be fine but I want to make sure before ordering everything!
thank you marcus!
You should be ok! If anything throw a little more lift/bump stop on there and carry on! Ha ha!
If you need help with the Poly stuff let me know, I can answer your questions and help you with a good deal.
Marcus
