Here "Michael",,..new sticker for your "Hybrid Rubi"
Glad to see our parts are going out to somebody willing to abuse them.
I'm also going to be installing the Poly track bar bracket, as I want to install their high steer drag link.This unit appears to be very similar in design and function but with an added support.
I also figured while I'm there I will upgrade my tie rod (mmm Chromoly) and drag linkage to boot.
I am using a Napa stock replacement for a 06 TJ. It comes with a small bar extension to keep the shock off the frame. Works great out of the box without modification (after I drilled my hole in the track bar mount) plus it's much bigger than the stock JK steering stabilizer.:bounce:you just need a minimum 1 3/4 front bump stop spacer so the steering stabilizer does not hit the frame under full bump.
The Fox Emulsion shocks are also rebuildable. I went with some 11" travel ones, used JKS stud mounts at the front and JKS bar pin eliminators at the rear.The shocks I have elected to go with are the Fox remote reservoir shocks similar to these that are A) adjustable and B) rebuildable. You generally speaking don't need remote reservoir shocks for the everyday off road and rock crawling but the remote reservoir unit is the unit that is rebuildable and adjustable.![]()
Normal Fox 2.0 Emul. shocks are rebuildable, but the emulsion version of the Fox OEM replacement shock for JK's and TJ's has a welded top cap with a Bar Pin. It also has no Schrader Valve to relieve pressure, so it is not rebuildable. At least not with any tools the average joe has laying around. The remotes have a schrader on the end of the resi.The Fox Emulsion shocks are also rebuildable. I went with some 11" travel ones, used JKS stud mounts at the front and JKS bar pin eliminators at the rear.
Aha, you've found a rock magnet.Poly Performance's bracket, allows you to rotate the steering stabilizer up and out of harms way.
Otherwise you could have this happen to you....
Thanks, I didn't know that. Glad I went with 2.0's now.Normal Fox 2.0 Emul. shocks are rebuildable, but the emulsion version of the Fox OEM replacement shock for JK's and TJ's has a welded top cap with a Bar Pin. It also has no Schrader Valve to relieve pressure, so it is not rebuildable. At least not with any tools the average joe has laying around.
The welded stud tops have the little basketball valve in them. You can charge and discharge them with a needle.Normal Fox 2.0 Emul. shocks are rebuildable, but the emulsion version of the Fox OEM replacement shock for JK's and TJ's has a welded top cap with a Bar Pin. It also has no Schrader Valve to relieve pressure, so it is not rebuildable. At least not with any tools the average joe has laying around. The remotes have a schrader on the end of the resi.
If you were to be able to depress the seal carrier enough (against 200 PSI) to remove the retaining snap ring, I wouldn't wanna be around to see you remove the carrier.
