1 - 20 of 25 Posts
So I have came across only a few "dipped" Jeeps and it seems they've all been Matte Black. I decided I would post up my Camo Tan JKU for anyone looking to do a change with their Jeep like I was. I recently moved to AZ and found it pointless to wash my Green Jeep because it seemed to always remain dusty so to say. I originally wanted to go with some crazy stand out color but Plast Dip in gallon form really isn't as cheap as some think it is, it isn't expensive by all means but when prepping to do your first job it can get up there. I decided I would do Camo Tan because it has good coverage and I could buy it un-thinned meaning I thin it myself and end up with 2 gallons of Plasti Dip for the same price that dipyourcar.com charges for 1 gallon of ready dip spray.
The key to a good smooth plasti dip job is coats. I ended up laying down 6 coats with 2 gallons and feel like I got pretty good coverage I wouldn't have minded having another 1/2 gallon though just to do a few more coats for good measure, but since I will be doing another color at some point, I am happy with my current results.
Wheels will probably get done black as well but I am currently deciding on what color I want to ultimately do and will take it from there. I plan to at some point do my bumpers and sliders black because that will probably go better with whatever color I end up going with next. Just so I could get full coverage on the bottom of the Jeep I went ahead and sprayed the sliders so will just peel it off later. I also removed the grill and sprayed it off the Jeep. With my winch and light mounted on the bumper this was the easiest solution for me. As far as taping off around the soft top, that was a pain because tape doesn't really hold to the top so there are some spots where the tape came off and I got dip on the top but rubbing it with my finger brings it right off so no worries on overspray getting on your soft top.
Here is the sources and sprayer I used to complete this for anyone out there thinking about doing this:
Plast Dip: www.awarehousefull.com Again you can buy un-thinned dip and then buy a gallon of thinner from Home Depot or Lowes and end up with 2 gallons for about $40 cheaper than buying ready dip spray.
HVLP Sprayer: http://www.provantage.com/earlex-hv3500us~7EARL004.htm--Cheapest I could find the Earlex 3500 for @ $114.95 shipped--Add it to cart to see final pricing
You will also need tape and newspaper/plastic to tape off things you don't want to peel obviously. To save dip I highly recommend masking off windows.
There is a couple of forums out there dealing with Plasti Dip so if your looking into doing anything with dip I recommend checking them out. Also dipyourcar.com has tons of youtube videos showing pretty much everything you need to know to do this successfully.
This stuff becomes pretty durable when you do it correctly and it can be washed and it can handle the elements quiet well. There is also pretty simple ways to fix accidental rips and what nots as well.
CalmerThanYouAre
I like the color, nice job.
R.I.P. Mr. Nibbles!
I'd do the wheels in the same color or something in the desert brown category to make it stand out and be different. Looks good, welcome to AZ!
Looks great man. Well done !!!
Actually ... I like everything coated the same color. Looks like a military truck.
Looks good. I did my wheels recently in black. I like the idea of changing the color of my wheels and jeep for fun and being able to change it back.
Looks good and welcome to the desert. It will certainly hide the dust. You will have to re-post after you've had a chance to put it to the test with the "desert pinstriping" when you hit the trails.
Discussion Starter #13
Finally did the wheels and did a few more coats on the Jeep so figured I'd do the hard top since it was on.
Looks awesome but I'm not sure if I like the back windows dipped. How much did you end up using? 3 gallons?
Discussion Starter #15
Yeah, I'll end up peeling the windows in the next few days im sure.
I used 2 gallons of camo tan mixed 1:1 with thinner, so ended up spraying 4 total gallons.
R.I.P. Mr. Nibbles!
I saw you on Litchfield about a month or so ago, I would have waved, but I was driving my work rig so you probably wouldn't have noticed. :lol:
Turned out good, definitely peel the windows. :beer:
Discussion Starter #18
Thanks.
Yea, I live at Waddel and Litchfield.
looks great. good idea on adding another gal. with only 2 it prob would have been hard to peel (the thinner it is the harder to peel). i used 3.5 gallons on mine. 1.5 in a gunmetal base and 2 of anthracite top coat. had planned on doing a digi camo with cans for winter but never got around to it. spring it will be changing to burnt copper.
1 - 20 of 25 Posts
