Agreed! EVO sliders are just evil!Love the EVO's, they just scream "beat me!"
Why did you not like the PS Brawler Rockers, if I may ask?Poison Spyder body armor and ORE sliders
Personal note FWIW: the only reason I have the body armor is that I installed Poison Spyder Brawler Rockers when they first came out. Like a few other things I did, eventually I removed the Brawlers and welded the ORE sliders on (what I wanted to do originally, but talked myself out of it). I installed the body armor cause I already had the nutsert holes drilled. If I was to do it all over again I don't think I would install the body armor ...I'd just go with the ORE sliders or PSC Rocker Knockers. Be real sure you want the body armor vs sliders before you start drilling into the body. IMO, good sliders will do what the body armor does and more.
Two reasons. I have always wanted the EVO sliders, and weight. The Brawlers are bloody heavy!!! My Jeep is a DD and I can put on up to 100 miles per day, so I've done a lot of recent work to reduce weight.Why did you not like the PS Brawler Rockers, if I may ask?
Rocker Knockers, IMO.Sliders are the next thing I'm looking into. I'm between 3 right now... Psc rocker knockers, ace sliders, or the pure jeep sliders. Hmmm?
Sent from my cardboard box using Tapatalk
Greg, the evo's are nice and look like they will take a beating. But like said for the price you can't beat ace! Most rockers bolt to the tub which IMO is not solid. A rail that bolts to both frame and tub is ideal. Ace rails bolt to the frame only but are very solid! I have taken some massive hits at RC and aside from the scars they are good to go. I will be in the pines for the holidays if you want a closer look.Sliders are the next thing I'm looking into. I'm between 3 right now... Psc rocker knockers, ace sliders, or the pure jeep sliders. Hmmm?
Is it a good idea to bolt to the frame and the tub with sliders. The tub moves slightly with rubber body mount bushings. Bolting the two together might cause problems.Greg, the evo's are nice and look like they will take a beating. But like said for the price you can't beat ace! Most rockers bolt to the tub which IMO is not solid. A rail that bolts to both frame and tub is ideal. Ace rails bolt to the frame only but are very solid! I have taken some massive hits at RC and aside from the scars they are good to go. I will be in the pines for the holidays if you want a closer look.
