I'm running a 4.88 with the pentastar fan. Using a aeroforce gauge at 285 at the worstspecs? I know you have 40s but what gear ratio? guessing non pentastar fan?
Also are you monitoring the exact temp or just seeing the temp needle go hot?
We breakout a connector with two wires(blue-green) for fan control with our harness. We use the stock JK fan controls on many builds and have the option to use the GM ECM to control the fans. We can support single DC fan motors, dual DC fan motors and various variable speed fan motors using these two wires. The ECM must be programmed for the fan you are running.There is a green and a blue wire coming out near the bussman fuse block that I believe you said were the controls for the fan when I decide to upgrade to the pentastar fan.
Ok. I know I asked you to make sure to program the ECM for the pentastar fan upgrade even though I wasn't going to put one in right away when you sent me the ECM. Other than actually installing the fan, is there a way to tell if the ECM was in fact programed? ( this is Jon from Ohio who had to get my ECM reprogramed due to the speedo being off by 7mph the first time).We breakout a connector with two wires(blue-green) for fan control with our harness. We use the stock JK fan controls on many builds and have the option to use the GM ECM to control the fans. We can support single DC fan motors, dual DC fan motors and various variable speed fan motors using these two wires. The ECM must be programmed for the fan you are running.
If you asked us to set up the ECM for a Pentstar fan even though you are not using it we would have. You can still run the stock JK fan control through the TIPM, then when you are ready add the Pentstar fan.Ok. I know I asked you to make sure to program the ECM for the pentastar fan upgrade even though I wasn't going to put one in right away when you sent me the ECM. Other than actually installing the fan, is there a way to tell if the ECM was in fact programed? ( this is Jon from Ohio who had to get my ECM reprogramed due to the speedo being off by 7mph the first time).
Ok. I just bought one today from the dealer. Going to make my own harness with 8 gauge wire and a 100amp fuseable link. I should be able to command the fan on with my scanner to make sure everything is working correctly then,right?If you asked us to set up the ECM for a Pentstar fan even though you are not using it we would have. You can still run the stock JK fan control through the TIPM, then when you are ready add the Pentstar fan.
I don't remember off the top of my head but it's the wire going to pin #58 connector 1 of the GM ECM. 8 gauge wire is fine. In our harness we include the connector so the fan plugs in, without the connector butt splice the wires securely.Ok. I just bought one today from the dealer. Going to make my own harness with 8 gauge wire and a 100amp fuseable link. I should be able to command the fan on with my scanner to make sure everything is working correctly then,right?
Also which wire do I tie into for the fan control. Blue or green or both?
I can let you know tomorrow. That's when they are dropping off the fan and pigtail.Whats the P/N for the connector for the pentastar fan? I need to make my harness as I am getting close to starting this thing finally.
I would really appreciate that as my Google fu isn't strong enough. I Googled around for 15 minutes before I gave up to wait for a response here.I can let you know tomorrow. That's when they are dropping off the fan and pigtail.
That connector can be difficult to find, we stock them.I would really appreciate that as my Google fu isn't strong enough. I Googled around for 15 minutes before I gave up to wait for a response here.I can let you know tomorrow. That's when they are dropping off the fan and pigtail.
Can you share the P/N?That connector can be difficult to find, we stock them.
The dealer I got my fan from sent me the wrong pigtail..they are trying to find the right one now.I would really appreciate that as my Google fu isn't strong enough. I Googled around for 15 minutes before I gave up to wait for a response here.
Last I checked Chrysler was only servicing that connector with the harness, it's been a while and things may have changed but good luck.The dealer I got my fan from sent me the wrong pigtail..they are trying to find the right one now.
If they cant locate one can I buy one from you then?Last I checked Chrysler was only servicing that connector with the harness, it's been a while and things may have changed but good luck.
Me tooIf they cant locate one can I buy one from you then?
