1 - 20 of 22 Posts
Tested for the draw tonight and found a significant drop in draw when I pulled the 20A M3 fuse.
I believe this fuse is designated for the front and rear lockers so how exactly would I go about fixing this issue.
Mind you I have an Currie dana 60 in the rear with an ARB but the front is the stock Rubi 44.
Thanks.
How much of a drop do you see when you pull the fuse?
When you pull the fuse, is the total draw less than 0.035 amps?
The power that goes through that fuse feeds both locker relay coils, and both locker actuators.
I would remove the locker relays one at a time and see if that causes a drop in the draw.
I get a .14 amp drop when I pull the fuse. Looking at the relays was going to be my next step. Could a bad relay be the culprit?
Oh and total draw is still at .11 amps after pulling the fuse…starts out at .25 amps.
Probably still need to find the other draw but trying to fix one at a time.
Leave M3 out, and continue pulling fuses to see where the other draws are.
So I kept investigating and found that the other drain is coming from something related to my LS swap. I pulled one of the fuses from the LS fuse block and my drain went to basically .02 amps which is good.
Problem is now how do I fix the issue? The swap was done using the Motech kit and I know they had issues a long time ago but this is a newer harness and shouldn't cause a drain. Probably need to talk to Robbie.
Im experience some sort of draw also. Pretty terrible with the wiring part of vechiles. It will drain my battery in a day of sitting. Makes a clicking noise when i connect my negative battery terminal any ideas? Or how to test anything?
Discussion Starter #11
First disconnet your negative terminal on your battery and separtate it from the battery post.
Then with a digital multimeter on the 10A setting, connnect one lead of the multimeter to the negative on the battery and the other lead to your disconnected negative cable from the Jeep.
After you have it all connected you should see a number that represents the key off drain on your system.
Then start pulling fuses and when ever you see a drop in the amps you know that's the system causing your drain.
Make sure you don't have any doors open or anything else on that could cause the draw before starting the test.
Pull your M3 fuse and see if you get a drop in amps like I did. Below is a link to a video that explains it pretty good.
What you wrote is pretty good. I would add, the ignition off draw on our JKs will be high until about 5 minutes after you make the connection, as it takes that time for all the systems to shut down.
Also, once you make the connection, make sure it's a good one, because if you loose continuity, the wait time starts over when you re-establish the connection.
Normal ignition off draw for our JKs is about 0.035 amps.
edit to add:
I finally was able to see the video. This guy covers the subject very well, making some of the points usually left of instructional videos.
Very good, and worth watching.
Discussion Starter #13
edit to add:
Well said especially about keping the continuity. If you don't have good clips it's tough to keep a good connection
I still haven't found a solution to the draw coming from the M3 fuse unfortunatley.
Since I only have a front locker (rear has an ARB) I swapped the rear locker relay into the front relay position to see if there was any change but no luck.
What in the locker wiring could cause a draw like this?
So its been i bit i tested how you guys said. Getting a .64 only time it drops is when i pull the iod fuses which makes since. Went to hook my cb back up last weekend and noticed when i put my mountng bracket against my cage it sparked. No power wire hooked up to it ? Any clues
Static discharge?
Does anyone know if the hood pin switch needs to be depressed while testing for parasitic draw?
I don't see anything about it in the service manual's description of the ignition off draw test.
Remove the under-hood light bulb if you have that option.
1 - 20 of 22 Posts
