Guys,
If you need to switch-off the ESP for various reasons e.g. Sand Driving in the Dunes or better braking in snow, I have solved the problem by adding a "kill-switch" to the fuse J6 as illustrated in the two photos attached. When you turn the switch "off" the circuit is broken and the ABS pump is off and all ESP functions are canceled, of course your instrument panel lights-up with the ESP, ABS and TC lights. Once you finish, turn the car ignition off, then put the kill switch back on, ignition on, drive a few feet, all light go off and car is back to normal ESP functionality :devil:
