1 - 20 of 34 Posts
Vendor
ORI STX Struts at CCOR.
Available in 8", 10", 12", 14", 16", 18", 20"
If you haven't heard about ORI Struts yet...
Made in the USA, the struts' innovative design features dual pressurized chambers and internal bypass design allowing stability as well as comfort on road or off road! They aren't just for buggies and they can make your built JK ride like a Cadillac!
Give us a call to order, or if you are local to Athens, GA, we can install a full set up for you!
706-559-9609​
Some of the features of the ORI STX strut include:
  • Dual-pressurized chambers that provide for unmatched body roll stability in fast turns and on off-camber side hills. Set them to mid-stroke ride height and you can still control body roll without pushing off.
  • Specially designed compression damping valve that rushes oil back into the main cylinder 60 percent faster
  • 3-stage, velocity-sensitive compression damping that changes your soft ride to firm compression damping as the speed of the piston shaft increases.
  • Adjustable nitrogen gas pressures make the struts tunable, so you can choose a firm ride or loose articulation.
  • 2-inch piston
  • Compact design fits into tight spaces and makes many additional pieces of hardware unnecessary.
Velocity-sensitive, 7-position externally adjustable rebound damping.[/LIST]
  • Internal hydraulic bump stop on compression stroke.
  • Hydraulic end-of-stroke cushioning at full extension.
  • Cooling fins to dissipate heat and boost performance.
  • Lightweight, high-strength construction, featuring billet 6061 aluminum, stainless, and carbon steel.
  • Hard chrome steel cylinder and a tough 1¾-inch piston shaft.
  • Teflon-lined spherical bearings for ½-inch and 5/8-inch mounting bolts.
  • High-pressure 5,000-psi seals for extreme off-road use.
  • Operating temperature range from -65° F to +285° F (-54° C to +140° C).
  • Corrosion-resistant anodize outer coatings, ensuring years of performance.
Call, PM, or Post up for pricing.
Lead time is down on these!
Call, PM, or post for CCOR deals on ORI struts
706-559-9609​
Whats the lead time one a pair of 14's
I placed an order a month ago from another vendor and was told the lead time was 18-20 weeks.
Vendor
Discussion Starter #10
706-559-9609​
  • 2-inch piston
Vendor
Discussion Starter #13
706-559-9609​
  • 2-inch piston
1 - 20 of 34 Posts
