So here's the start to my long overdue 1 ton swap. My goal is to have it all wrapped up around May.
The goods:
Front - 02 Ford SD Dana 60. All the brackets/truss are going to be CNC cut, one off, here at the shop. It's going to be loaded with Yukon 5.38's, Yukon lockouts, Yukon zip locker, factory ten 35 spline outer stubs, custom machined unit bearings drilled & bored for 35 splines stubs & 8 on 6.5.
Rear - Good'ol 14 bolt. I'm going to be shaving it with a TMR 15 bolt shave kit, custom VKS diff cover, Yukon 5.38's, Detroit locker, disc brake conversion.
I'm also going to running a custom 3 link front and rear. In the front I'm going to be running 12" Fox CO's and 14" frenched outboard in the rear. All the towers are going to be VKS customs as well.
So stay tuned! I'm going to be keeping it updated daily.
Now for some pics. I got all the OEM brackets cleaned off and I'm going to be dropping them off to get blasted tomorrow. I also have the front truss mocked up in the mean time.
The goods:
