What have you guys used to widen shackle tabs?? My PSC bumpers have the tabs drilled for 7/8" D rings...(7/8" D rings wouldnt even fit) And I'm trying to open them up to 1 1/8". I have access to a plasma cutter if need be, but that seems a little sloppy.
Seems the only route I have is to buy a 1 1/8" metal bit, which is fine, but then I'd need a drill that will fit the (probably almost 1") shank....
I've tried small grinding wheels and a few other things, even a 1/2" metal bit working the outsides of the holes. After about 2 hours I managed to get one almost big enough.
Any ideas?? I'd like to use something I could pick up at home depot for a few bucks, never knew it would be this difficult.
