1 - 1 of 1 Posts
For Sale - Nearly New Mopar / TeraFlex Heavy-Duty adjustable tire carrier and hinge ($500 OBO).
This Carrier was removed from my '17 JKU after I brought it home.
PayPal or Cash only $500 - serious (LOCAL Phoenix) buyers/offers only, please
Designed to accommodate up to a 37" tire, the JK/JKU ALPHA HEAVY-DUTY HINGED SPARE TIRE CARRIER & ALPHA HEAVY-DUTY ADJUSTABLE SPARE TIRE MOUNTING KIT will secure your spare tire over the most extreme trails and rugged terrain. Our hinged spare tire carrier offers easy access to the rear cargo area in one smooth action. Using the factory tailgate hinge mounting points spreads the load of the spare tire over a larger area for maximum strength and durability.
Dedicated tooling and A356.2 T6 cast aluminum construction with a UV top coat, make our ALPHA HEAVY-DUTY HINGED SPARE TIRE CARRIER as light and as strong as possible, while its design, fit, and finish complement the JK Wrangler and JKU Wrangler Unlimited models' body shape. Internal gussets and bracing in the stock Wrangler body supports the Alpha tire carrier and oversized tire.
Heavy-Duty forged steel brackets and heavy-duty 5/8" hinge pins constructed from fold formed high-carbon hardened steel combined with the factory mounting locations ensure the strongest rattle-free tire carrier available. With the heavy-duty reinforcement carrier supporting the weight of the tailgate assembly and spare tire, the Alpha tire carrier removes all stress from the tailgate.
The Alpha tire carrier also provides additional mounting points for off-road accessories such as a recovery jack and fluid containers.
FITS:
• JK Wrangler (2-door)
• JKU Wrangler Unlimited (4-ddor)
SPECS:
• Allows adjustment for up to 37" tire
• 5x5" wheel bolt pattern
INCLUDES:
• Alpha HD Hinged Spare Tire Carrier (# 4838100)
• Alpha HD Adjustable Spare Tire Mounting Kit - 5x5" (# 4838130)
FEATURES & BENEFITS:
• Innovative & unique patented design (USPTO: # D6982240)
• Maintains single one-handed entry to the rear cargo area
• Threaded mounting holes for mounting accessories (fuel cans, recovery jack, etc.)
• Eliminates tailgate stress & rattles
• Simplicity & ease of installation - can be performed using common hand tools
• No drilling required
• Factory form fitting geometry & finish. CAD-designed tooling follows the precise compound curvature of the Jeep body, resulting in a carrier w/ an OEM appearance
• No aftermarket bumper purchase required - works w/ OEM & most aftermarket bumpers
• Strong & lightweight A356.2 T6 cast aluminum
• 14,000-cycle severe duty slam testing
• 1,000-hour extreme salt spray testing
• OEM Quality UV resistant powder coat finish
1 - 1 of 1 Posts
