Shagg,We've got a lot of Happy customers with this kit. VIAIR makes some great Electric kits at a decent price.
VIAIR CONSTANT DUTY ONBOARD AIR KIT
would 100 psi be a good "in the middle" type of reg?150 to 200 fixed regulator if you just want to fill tires. If you want to use air tools as well get one with an adjustable reg so you can drop it down to 90 when you want to use air tools.
The 400P doesn't really have the duty cycle to keep up with air tools. you'd need a pretty good sized tank. I would go for at least a 450C Pump or greater. If your looking for something more permanent and the sound of the pump going on and off doesn't bother you, then I doubt your going to find a better set up at the same price as VIAIR stuff.Shagg,
I would love to have a dedicated air source onboard and I have a Viair 400P. Would you recommend using this or should I look into one of the solutions that were designed to be permanent? If this could be mounted, wired and plumbed, is there anything I should watch for?
Thanks,
CO2 TANKS are damn convenient though. It's portable and always on, just sucks when you run out.
:beer:
