This is a very nice kit that takes the diameter of a larger Tie Rod and the size of an aftermarket Differential Cover into account.
This kit provides 2 offset GM 1 ton TRE's (1LH & 1 RH), the jam nuts, Hex Head weld bungs, and 54" of 1 1/2" X .25" wall Dom tube.
You may have to ream your knuckle's taper (depending on which knuckle you use) to accept the GM 1 ton TRE but the end result is more than worth the effort!
These have become the mandatory choice for the Jeep JK model as the only ones in the 1 ton size that will work with the factory knuckles.
Offset Tie Rod Kit - RuffStuff Specialties
