ok a quick run down. I changed plugs on the 2007 Jku 3.8 6 spd. I wasnt done and the cylinder #2 wire was just hanging while I went to work then, my wife drives the jeep 2 blocks and the check engine light comes on, she sends me a text about the issue and I said "thats because I never hooked up the plug wire on #2 cyl" so, thinking this is no big deal I get home put the wire back on clear the code and start it up.........And it still misses on 2 and 5 cyl which means the coil so I buy a new coil,test the resistance on the plug wires,check continuity on the wires from coil to PCM,and new plugs,I disconect the Battery overnight ....And it still is not fixed does anyone know if something in the PCM goes into limp mode and needs reset like a reflash or maybe a hend held tuner like diablo intune would help ....... right now Im really in need of Ideas or answers :gluging:
