Recently hit a bump and my radio went dark. Dash indicator said No Fuse. When I stopped I checked fuses and found none blown. When i started jeep radio was working again. It has happened several more times. Anyone else experience this?
Brand new 2012??
I had the same problem,dealership did not push the fuses in before selling it, they ship not pushed all the way in, lazy very lazy
Pushed down on all an no problem since
I have a similar problem. Radio working fine hit a bump or just starting the jeep radio doesn't play or quits. Then latter comes back on. When this happens face goes dark but buttons stay lit. Sorry about high jack. I will check this out.
Make sure the "Ignition Off Draw" fuse is good, and is properly seated.
With the key off, pull it up, then re-seat it.
Just had this happen on my '12...same issue. IOD fuse was not pushed in. Thanks for the help, it saved me a trip to the stealership! I loves the internets!
