1 - 10 of 10 Posts
I got my first Jeep (2007 Sahara 4 door) and am completely lost on a couple issues. And yes I have been searching the forums I know how forums are but all the info Im finding is for people get more extreme than Im wanting to do.
First off is tires. I am not wanting to do the big lift with huge tires as I will be using the jeep in the mountains in Colorado and everyone I have talked to says the closer to stock the better so you dont have problems on the mountain passes. However I want to get another set of tires and wheels so I can do some light playing on sand dunes/forest trails etc. So what is the largest tire I can put on my jeep without a lift, and if I do say a very small lift 1-2"'s then what size can I do. And is there alot of mods needed to do a small lift?
Also here is a pic of a jeep I almost bought and I really liked the wheels on it but dont know what they are does anyone by chance reconize the branding on the center cap?
Does anyone know where I can get a chrome tube bumpers like these?
And the salesman "threw in" a soft top that he took out of a new jeep on the lot but when I went to put the top on there wasnt any windows in the top...Do new jeeps with the hard top / soft top combo come with the windows, are they stored somewhere else or do I have to buy them seperate
Here is the jeep I ended up buying but I really like the looks of the red one above and would like to make this one look similar
I bought both tops for my Jeep. The softtop came w/ two boxes in the Jeep. I think one had the windows, and the other one had the door surround things.
In regards to a small lift, I have zero "mechanical skills", but I'm about to do either a 2.5" Teraflex (brand) budget boost (basically, pucks that go on top of the factory coils) or a 2.5" Teraflex coil boost. If you go over to quadratec.com's website and look up either product, you should see the instruction PDF there. There's also a few write-ups on Jeep forums like this. I'm nervous, but I know if I follow the instructions (and write-ups), I'll be fine, and I'll learn a crapload about my Jeep in the process.
IIRC, you can run 35" tires with a 2.5 lift.
My Rubicon came with 32" tires that I'm loving on the beach and forest trails. I'm not going to upgrade to anything until they're worn out!
Congrats on the new Jeep. I have the dual tops and it comes with two boxes, one for the windows and one for the door surrounds. You'll need those.
Is that all i need is the door surrounds? In the manual it looks kinda like the is some kind of hook above the doors that holds the soft top. Any ideas on a cheap place to find the surrounds, they are pretty proud of them.
Welcome ...look into a budget boost and 33" tires. Even with stock gears it'll perform pretty well ...then eventually look into 4.56 or 4.88 (if you start thinking how damn cool 35" tires would look).
with a 2.5" lift (very easy to install and doesn't require changing a lot of suspension items), you can run 35" tires.
BUT- your friends are correct about the mountain passes. You did not indicate if you have an auto or manual. A manual will perform a bit better. But regardless the gearing is too low to be able to maintain speed on uphills with 35's. So you'll want to regear if you go 35" tires. Generally, 5.13's for auto and 4.88 for manuals. But in a mountainous area it might be beneficial to go with 5.13's in a manual or 5.38 in an auto.
and your gas mileage is going to suck regardless :laughing:
I'm running 35's with 5.13's in an auto, and live in flatlands. I get 13mpg city and 16mpg highway (with a tail wind :laughing:)
to add to N2rock, the altitude will affect your performance differently as well. You won't get that nice rich air at sea level as you will in the mountains, I'm sure you know. So your Jeep will be even more sluggish without a regear than it would be in the midwest or the coasts.
Hi Jonas, welcome to JKO!
Why is everyone telling him about 35s!? He said he DIDNT want to lift it.
Jonas, my advice would be to put some all terrain tires on your stock wheels or even get a set like the ones pictured and put tires on them. The sahara rims are 18" diameter and tires will be pricey. You can always sell them outright on craigslist or talk to Discount Tire about a trade in.
I would look at 33x10.5 to 33x12.5 tires for your Jeep for use in the mountains and fire roads. They will do just fine for you and keep you from needing to re-gear in most cases.
As far as the soft top goes, call the salesman and tell him you didn't get all the parts. If he took it off a new one then he should give you all the parts. But...that doesn't sound like something a dealer would do in the first place. Seems a little sketchy to me.
Good luck either way and don't feel like you need 2.5" of lift to change your tires.
1 - 10 of 10 Posts
