Hi everyone, finally made the plunge and now have a JK!!!!!! Now it's time to add on the goodies. With the help of this forum, I've got my winch plate (Rough Country) and winch Smittybilt on order. Now I want to put some off road lights, mounted at the wind shield, on. I've tried the search avenue, but alas I can not find any threads that talk about the actual wiring for lights mounted at the wind shield. Can any of you more knowledgeable jeepers head me in the right direction????? I see where the wiring appears to go down the channeling at the base of the wind shield, but I can not tell what is the best way to get the wiring into the cabin...
Great forum y'all have here!!!!!!
Thanks in advance,
Paul
Should be directions with the lights.
Basically, wire goes from battery to relay to light. Then wire from light to ground. Another wire goes from relay to switch and ground. Done.
