*NEW PRODUCT* POLY PERFORMANCE JEEP JK Trackbar Relocation Brackets W/Cam Adjuster-->
Poly Performance Jeep JK Front Track Bar Bracket:
Description:
-Compatible with 3.0" and taller lifts
-Heavy duty front track bar bracket for the Jeep JK
-This bracket raises the vehicles suspension roll center by 3.0"
-Option cam bolt adjuster allows for easy adjustment for lifts taller than 4.5"
-Special bolt on design strengthens the factory mount that is prone to failure
-Raising the roll center reduces vehicle body roll and dramatically improves overall handling
-Laser cut from 3/16" steel & 2 stage powder coat finish for maximum strength and durability
-The bracket relocates the factory or aftermarket steering stabilizer up and out of harms way
-Suspension components feature an abrasive resistant powder coat finish for maximum durability and corrosion resistance
-100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
Poly Performance Jeep JK Rear Track Bar Bracket:
Description:
-Heavy duty rear track bar bracket for the Jeep JK
-Designed to work with 3.0"4.5" lift heights with factory track bar
