This is a write up for the new KC HiLiTES JK H4 Headlight Kit.
Tools needed
Flat Head Screwdriver
T10 Hex
Favorite beverage
Yep it's that simple!
New Headlights
Lets get this started!
STEP 1. First open your hood
STEP 2. You will see 6 black tabs running across top of grille. You will need to pull both parts of the tabs before removing.
Once the 6 tabs are pulled you will then move on to back side of grille.
STEP 3. There is 2 bulbs that will need to be removed before pulling off grille. On each side of grille at 3oclock and 9oclock. Just twist and pull to remove.
STEP 4. Now that you have bulbs and the 6 tabs removed we can now pull off grille gently. Start by pulling above headlights (gently) and move towards bottom corners of grille.
STEP 5. Around headlight housing you will see the hex bolts. This is where you will use the T20 hex to remove.
"THE SILVER HEX BOLT IS FOR ADJUSTING HEADLIGHT UP AND DOWN"
STEP 6. Once you have removed the hex bolts you can now start fully removing the headlight housing.
STEP 7. On back of headlight housing you will need to pull red tab up then push in the thumb press to remove bulb
STEP 8. After bulb is removed, you will need to take off the trim ring (some will need to pull from these tabs to remove)
OK LETS GRAB NEW HEADLIGHTS!!
STEP 9. Take the trim ring and put over new headlight housings
Now that the headlights are ready to be re-installed, let's go do the H13 TO H4 wiring housing
This is what your stock wiring should look like
STEP 10. Now take the new wiring that came with headlights and plug into old wiring housing
STEP 11. Plug new wiring into new headlight housing
STEP 12. Line up trim ring to hex bolt mounts
Now that your headlights are remounted its time to put back on grille.
STEP 13. Line up grille on top to the holes where you pulled out 6 tabs on STEP 2
STEP 14. Line up bottom tabs to the rectangle holes and spring clips mentioned above
STEP 15. Once grille is lined up start pressing in gently for everything to snap in place
STEP 16. Install the 6 clips that you removed on STEP 2 (put bottom part of clip on first then line up male clip and press in
STEP 17. Reinstall the blinker bulbs you removed on STEP 3
STEP 18. YOU ARE DONE!
THE KC LOGO GLOWS IN DARK!
Tools needed
T10 Hex
Favorite beverage
New Headlights
