Hi all... I'm new to Jeep and awaiting my 2014 JKU Sport. I've been lurking here for a while, trying to use the search option to it's fullest. I'd like to get your advice on a specific wheel/tire combo that from what I've read, is not perfectly ideal but should work. Thanks for the many backspacing/offset threads and guides.
2014 JKU Sport S
5sp Auto
3.21 gears
stock 17" 255/75/17
90% on road/10% off (mud/gravel/grass)
daily driver
My idea is to get 17x9" Raceline Raptor wheels (5" backspacing) with Goodyear Wrangler Duratec 285/70/17 tires. Any clearance issues that you can think of with a stock suspension?
xvcrysisxv... I know you put the 17x9" Raptors on your stock Wrangler at the time. Any clearance issues up until you installed your lift?
Thanks, I appreciate any input!
Welcome to the forum!
I run 8" wide wheels with 4" backspacing and it sticks out a good 2 inches past the fenders. It sounds like from your description you don't plan on flexing out your suspension so I would think your setup would work, as long as you dont mind the wheels being outside the fenderwells.
Thanks Mike! I appreciate the feedback!
I really like the Raptors but I guess that's the problem with first, finding a wheel you like and then second, checking to see if it fits. I know I should have worked the other way around.
What makes me hesitate about a lift is mainly garage clearance ( I only have a few inches of clearance to play with at stock ride height) and any warranty/dealer problems. A few years down the road, it won't matter as much.
Thanks again...
Jason
I'm in the same boat with garage clearance. With 33's you won't gain much if any height over the stock wheels and tires. My new 33" duratracs are maybe 1/2" higher than the factory tires. They are wider and much more aggressive which makes the Jeep look higher, it's a weird optical illusion. I did go with a JKU Rubicon spring and shock take off package which was cheap and gave me about an inch of lift and a much better ride. I still have about 3-4 inches of garage clearance if I decide to go higher.
