This was just released.
Warrior's Rear Rock Crawler Bumper for 07-08 Wrangler/Unlimited
Shown attached is the bumper installed on Warrior's 07 Unlimited. Some of the complaints I've seen so far with other bumpers is their closeness to the body. This bumper does not extend higher than the frame rails, thus keeping it away from the body.
It does however create a 2.5" gap between the bottom of the tailgate and the flares, creating the need for a filler plate. The Rugged Ridge line handles this the same way.
There are a couple of options here. The first is this if you're going to run corner plates. This shows the bumper with installed 920A-1 Corners and 920D Backplate.
Also, this filler plate is an option but does not cover as much. Part # 920D-1 filler plate.
The bumper uses 3/16" mounting plates, attaching to the factory 4 bumper bolts on the frame rail sides, and also to the 4 factory receiver mounting holes in the x-member. The receiver is your standard 2" class 3 style, and the exterior skin is 11 gauge HRPO steel. It's not thick 3/16" material, but it keeps the bumper lighter and cheaper. A good budget option. There are also 3/16" struts inside the bumper stretching from the outmost end to the mount plates, making the ends much stronger.
They come in at $310 shipped to your door in the lower 48.
http://www.rjroffroad.com/Warrior-R...r-07-08-Jeep-Wrangler-c-558-p-1-pr-17222.html
