1 - 9 of 9 Posts
Guys
We have a Currie Dana 70 High Pinion rear axle assembly with full float axle shafts, 5.38 Gears, Eaton E Locker, WMS of 67 3/4 using JK Brakes. This axle assembly has not even been broken in yet. It was used for Moch Up only in a Rock Racer 4 Door Kit and still has the tags on it. Retail Price $5500...
Asking $4000 obo. All brackets can be stripped by us as well so you get bare tubes.. Give us a call at 518-270-9822 to get a good deal on an axle...
RK
Same question as above regarding tone rings?
All 35 spline I'm guessing? (Not their 40 spline stuff)
1350 U-Joint?
Anyone in particular I should ask for, will try to call tomorrow during work if I get a chance.
Thanks.
Sorry for the delay.
They do have tone rings and e brake components already on the axle assembly.
The high pinion will work with the Rock Racer System if you use our DIY rear upper reverse triangulated 4 link assembly and do a fuel cell in the vehicle or behind the rear axle....
If you want to call and talk to anyone regarding this axle, give Jeremy a call in the office. He knows the most about them...
RK
1 - 9 of 9 Posts
