Alright so i have a 2007 jeep jk 4door unlimited X 6 speed manual, dana 44 rear, dana 30 in the front, brutal 3.21 gears. Before i go and buy all this i just wanted to make sure what im buying here is good for a daily driver mostly highway to work and trails here and there but want to get more out of it but not wanting to Just Empty Every Pocket. Thanks in advance guys, really appreciate it ! :bounce:
3 inch lift
35s
4.88
With the lift i came across two lifts that from what i see look both the same, but not to sure on quality.
First one is Teraflex 3inch lift with 4 flexarms(the arms are front lowers and rear uppers) and no shocks, as i will be getting Bilstiens 5100 shocks, heard really great reviews on them.
Secondly is the Rancho 3inch trail system with no shocks, again ill be getting the Bilstiens 5100s, heres the catch this lift kit come with 4 flex arms but its the front lowers and the rear lowers, if i heard correctly at minimum you need your front lowers and rear uppers? Also this lift includes the front adjustable track bar. (one thing that i like about Rancho is that there springs and arms are red, which if i was going to go with any other lift i would have painted it red but if Rancho lift is really all that good then i wont have to paint it.)
As far a tires go, my mind is set on 35s love the look and not to sure which brand to go with havent really looked into that yet. To run 35s obviously i need to re gear. So im set on going with a complete overhaul kit to 4.88 and with the front as a dana 30 the carrier wont fit anything above 3.73s so i need to get a new carrier, I do have links on the products i am going to be purchasing hopefully before summer gets here.
Teraflex 3inch lift (NO shocks 4door)
http://www.teraflex.biz/jk-wrangler-3-suspension-system-w-4-flexarms.html
Rancho 3inch lift Trail System
http://www.gorancho.com/suspension.php?make=Jeep&model=07_12_jeep_jk#lift
4.88 overhaul kit front and rear
http://www.4ws.com/jeep-wrangler-jk-gear-and-install-kit-package-front-rear.html
Dana 30 carrier 3.73+
http://www.4ws.com/dana-30-3-73-carrier-w-thrust-washers-jk.html
3 inch lift
35s
4.88
