Need Help...
904 Views 2 Replies 1 Participant Last post by  airric00
Anyone with a Skidrow Tranny plate having trouble with rubbing on the Front drive shaft?? At full flex I am getting a slight rub on the middle driver side end of the Skidrow plate. On the street its fine.. Disconnect the sway's and flex the passenger side wheel up, it rubs like crazy. I don't want to break my driveshaft on the trail... Even though I have a spare its a biotch to change out.. (from experience)..
G
I had to grind my rubi tranny skid plate down a bit to clear my DS. I have an angle grinder etc. and you’re welcome to come by see what I did and use my stuff.
Thanks... I need to get you back the CB as well. I'm guessing that is the problem too.. I was wondering if maybe since I haven't extended my front brake lines that were becoming to taught and pushing the shaft into the plate? Hmm.. Either way those need extended and a little grinding can't hurt! You available this next Saturday?
