Hey guys installing a push button start into my 07 jk. I need the wire colors for the following things if anyone can help!
On Disconnect - ?
Start wire- believed to be pink and white I think
12V- Red wire I believe
ACC- I think is violet and brown
ON (constant power when on) -
brake light wire - white and tan
Oil path wire -
direction light wire -
I know this is a lot if anyone has just a diagram that shows these wires that would be awesome, I've look and can't seem to match up the wires this is what I have and what the kit shows. everywhere I look the blue/white wire along with the green and white are not listed
Found this on a quick search. Please make sure to double check all wires with a multimeter to verify
2007 Jeep Wrangler.
Vehicle Battery Positive Wire (+): Light Blue/Red (This wire only supplies 10 amps of current. For any high current needs, go directly to the battery or the TIPM under the hood.)
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Pink/White
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Violet/Brown (Accessory is (-) through a 560 ohm resistor. Same wire as starter 2 and key sense.)
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Yellow/Gray (Not For Remote Start)
Automobile Engine Starter Wire Location: Pin #8 in Blue Plug at TIPM On Passenger Fender Under Hood
Automobile Second Engine Starter Wire (-): Violet/Brown (Starter 2 is negative (-) through a 180 ohm resistor. Same wire as accessory and key sense.)
Automobile Second Engine Starter Wire Location: Ignition Switch Harness
Factory Anti-Theft System: Sentry Key Immobilizer System
Factory Anti-Theft System Type: Key Sends a Signal to the BCM Module
Just a heads up, a site we used to use the hell out of in the install bays for schematics was the12volt.com. You should be able to choose your vehicle setup and what you're trying to do via drop down menus. Just a heads up, I know schematics can be a pain to hunt down at times.
