1 - 9 of 9 Posts
I'm wanting to take off this 1.25 body lift. I will trade someone if you are local in the Louisville area. I missed placed the oem hardware that I need to put this back the way it was. The hardware with the BL I have is to long to work with stock mounts. Email me at [email protected]
Sent from my PG86100 using Tapatalk 2
Do you have the stock mounts or just need the little studs that you press out in some kits?I may have the studs..
I just need the little studs that I pressed out of the oem mounts. It will be a pita to use regular hardware on these.
Can you count how many studs you need? I have a bunch
Sent via paper airplane
24 total. I could probably get away with regular hardware in the front 2 because I can get to the top of the bolt... So 20 to 24 of them is what I need.
I'll try to remember to check tonight. PM me if I don't get back to you
I have twenty from a JKU.
1 - 9 of 9 Posts
