Thanks, I'll open it up and compare the two. I am more interested in the throttle response and TCM stuff TBH. Though I will say that, IMO, mine runs very lean. Some days it runs like a raped ape, some days I want to rip the blower off because it runs like total crap. Are you active on the HPTuners forums?Remember, this is Sprintex which has different injectors and MAP sensors, so you cannot directly load this. You'd have to correct those, and assuming the calibration may be slightly off on either for our calibrations of those sensors, the VE table could also be off as a result.
What MAP sensor does Sprintex use, the SRT4 sensor?
What injectors are you running? I keep meaning to pull one of mine to see what Edelbrock supplied with my kit. I know they are GM injectors and that's about it.
Mine also runs very rich when its cold but my buddy was able to clean that up a little bit compared to what it used to be it still stinks like shit if I leave it running in the garage for more than the time it takes to pull it out.
