Edelbrock supercharger install thread
Hey gang, I just thought I would share my experience installing the Edelbrock supercharger.
I went with this one because I am not a huge fan of centrifugal superchargers for low end torque and while I like the twin screw, I don't like the noise that can be heard in every single video and throughout the RPM range and apparently under any load. That and from what I have read, this kit is not made in USA or even Australia. Probably I am wrong so go fact check me on this one an report back.
Compared to the Magnusson, the Edlebrock has a slight edge for a couple of reasons. They supposedly use the same rotor pack in the blower itself but the edlebrock allows you to use the OEM oil filter and mopar hood lock and has a black (more stealthy looking) intercooler.
Due to lack of time on the home front, I had to time slice this over a weekend and it is still down due to waiting on a defective part not from Edelbrock. It is not yet on the road with the blower on yet but here are some initial comments....
I think the reason that this kit can use the stock oil filter is not only because the air inlet housing has a dent designed into it but also because the blower is shifted half way over to the driver side. The Maggie is a direct down flow as far as I could tell in the available online pics. You can see this in the video as well with the intercooler housing installed. I am not sure if this will have an effect on performance.
I plan to leave the stock software tune in. I restored my Diablosport tune back to stock and unmarried the device so that I could use the tune in the supplied SCT X4 tuner. I will run the canned software for a while and then revert it back to stock and pop in a custom tune via the trinity and an online tuner that I am working with. A custom tune is probably worth an additional 20hp and general smoother running all around.
What sucks about the Edelbrock supplied SCT tuner (or maybe I have just figured it out yet?) is that you cannot set any parameters such as axle ratio or tire size let alone muck with the sway bar or TPMS. It is JUST THE TUNE and an ability to log. You will still need a ProCal either way.
Fast forward to this post for a list of the issues that I have had:
http://www.jkowners.com/forum/modif...upercharger-install-thread-9.html#post4081089
