We were just given a pair of Rubicon Rock Rails (Mopar) without the mounting hardware for my 07 JK. Does anyone know of how I can the hardware that goes with it. I've done some searching on quadratec and mopars site and haven't found any yet.
Thank you,
I bought mine used with no mounting hardware. I found all of the bolts, nuts, etc... at Autozone.
I think they sell U-Nuts(Clip Nuts) 2 to a pack with bolts, You will need either 4 per side or 3 per side. You will also need 8 or 10, 10mm(head size) bolts. I think that is everything, been over a year since I installed them.
If you have an Ace Hardware nearby you can buy the bolts and the u clips there. I picked up a set too and got everything I needed at Ace. I also bought harder bolts.
Here are the sizes right out of the MOPAR Parts catalog, you will need four pairs of bolts and u nuts and four smaller nuts:
BOLT AND WASHER, Hex Head,M8X1.25X25.00
U-NUT, M8x1.25
NUT AND WASHER, Hex, M6X1.00
Two 8MM bolts hold the rails using the two 8mm u nuts. Get two 6mm nuts either with a washer or flanged. They hold the rails to the sills so you can securely mount the rails using the larger bolts.
So altogether you need four 8mm bolts, four 8mm u nuts and four 6mm nuts with a washer or a flange.
