Goodysgotacuda and I are both running the Superchips Flashpaq. I think he's on the Tow Tune, and I'm running the 91 Tune. They help out with setting the tire size, you can set the gear ratio (if you ever change it), and it helps give a little oomph in the ol' gas pedal. (Nothing Earth shattering, mind you, but it does help.)@merlin4979 -
Thanx for the response. Loox like I'll add Toyo to my list of tires to research. R u using any programmer or did u do anything to get the speedo to read things correctly after the tire change?
Yep. Tow tune here, couldn't justify the 91 for the cost of 93 fuel. I run the tow tune on 87.Goodysgotacuda and I are both running the Superchips Flashpaq. I think he's on the Tow Tune, and I'm running the 91 Tune. They help out with setting the tire size, you can set the gear ratio (if you ever change it), and it helps give a little oomph in the ol' gas pedal. (Nothing Earth shattering, mind you, but it does help.)
I also picked up a Sprint Booster. That helps a lot with the pedal lag and with acceleration.
Man! We love this jeep! What a great combo of colors and custom paint!
