Slade
Our play ground is on the trails. We would love to have you join us for a run anytime. Have you posted a pic of your jeep yet?
We posted our dimensions as we state they be used. It all depends on who's rule of thumb you would like to go with as far as thread engagement is concerned as to max. lengths. We posted our conservative numbers for you. Good luck....
RK
All you have posted is the recommended starting points.
How is it that you are capable of posting the target Minimum/Maximum length of a set of arms that are not even available BUT you can't post the Min/Max lengths for your current arms?
Your current arms along with the set of arms that "Terry... is working on" for 2016 will both share the same variations and different Rules of thumb for thread engagement....
Seems that you could just as easily post the same target measurements for your current arms as you did for your 2016 arms that are still in the works (BUT YOU WON'T).
If the Min./Max. lengths of your current arms would prove my criticism about your product wrong, I'm sure you would post up the numbers to prove me wrong and back up your product to make it look better (after all, you are salesmen). Doing so would also show your current customers along with your future customers the benefit of choosing Rock Krawler over some of the competitors that are already doing (and have been doing for a long time) what you plan to do in 2016.....
BUT you won't provide the minimum/ maximum numbers on your current arms. Pair that with the fact that "Terry" has a new set of arms in the works for 2016 that work with flex and X factor lifts from 1.5"-3.5" (like other companies already do) that address the very problem that I criticized you for....
It's safe to say that your NOT going to keep specs that help sell your product to your self and your NOT going to make another set of arms for 2016 (that would discontinue your current arms) if your current arms are covering all the bases
and providing a benefit that you won't get from your competition (why do what others are doing if you have already have an edge?).
It's funny how interested you are in what I drive. Like I said before.... It's nothing special just a baby hauler... Ill give you some quick specs.
2004 TJ, 4.0, 5 speed with 36k miles on it:
37" Pitbull Rockers (Bias)
stretched to around 106" or 107" and swapped to leafs front and rear (rear SUA/ front SOA), 44044 front leafs and chevy rear leafs, around 4" or so suspension lift. additional tire clearance comes from a 1" body lift and highline tube flares.
78/79 Ford Dana 44 front I narrowed to 61" (5 lug outers), Reid knuckles, RCV shafts, Detroit locker, 5.13 gears, high steer
Ford 8.8 rear, Superior shafts/c clip eliminator, 5.13's Detroit locker
4 to 1 t case
smoothed belly with raised motor and tranny
Body armor, tube flares, and the other usual shit.
The Baby Hauler is a 2013 JK, 6 speed, Q78 TSLs, 4.88 gears, Detroit Truetrac front and rear, 2.5" coils with 8 adjustable control arms, Currie Antirocks front and rear, 1.25" BL for additional tire clearance to reduce bump stop and get full use of 11" travel shocks. Like I said, nothin special. Just my DD and Baby hauler.
Wife's Jeep Is a 2014 JKU on 35's with an auto and 3.73s, leveled (1.75" rear/ 2.75" front).
Ive had quite a few other rigs if you want to know my life history. Ive had CJ's, YJs, a TJ, JKs XJs, an M715, along with Toyotas, Samurais, and a few Full sizes.
