Sorry for the crappy cell phone pix, my regular camera broke. I kept ripping off my fender liner and it was too beat up to put back on. So I decided to install Metalcloak fender liners to give my JK a clean look. They took about 1 hour to install after I sprayed it with paint. The install is easy.
You do NOT need Metalcloak fenders with these liners. I'm pretty sure they will work with any fender.
Overall I'm happy with this setup. I have more clearance to stuff my tire without ripping out the liner. My tire still touches the liner a bit on rare occasians but it's much better then when it was stock. When it was stock I would hit my airbox.
A pic of the JK...
Close up...
The kit comes with 3 pieces on each side. Labeled below is each piece.
It attached with 6 bolts. 3 are stock bolts and 3 have to be drilled.
For the first 2 pieces you must drill 2 holes and use one stock bolt. The 2 holes you drill are through 2 pieces of sheetmetal and you use a bolt about 3" long (if I remember correctly). Metalcloak does not prove the bolts. With stock fenders, you will not have a issue. With aftermarket fenders I don't believe there will be a clearance issue as well.
For the third piece you use 2 stock bolts and drill one hole in the empty spot behind the front blinker. You will not have any issues with any setup you have. I have TeraFlex Speedbumps so I had to do a slight modification (cut about 1" off the liner) to fit the speedbumps. You will not have this issue with any other bumpstops.
A pic of the JK...
Close up...
