Vendor
A while ago CARiD became a dealer of American Fastbacks - the aftermarket manufacturer of cool Jeep Wrangler body parts. These guys are famous for their hardtops, but there are few other remarkable parts in their product line:
Airborne Fiberglass Hood and Patriot Grille
#1 - American Fastbacks® - Airborne Fiberglass Hood
This grille doesn't only look great, but performs even better. We all know that Jeep engine can run hot and this hood will keep it cool using the functional ventilation openings.
It is installed on the OEM mounting points, and doesn't require modification.
View prices and more details on the hood here: American Fastbacks® - Airborne Fiberglass Hood
# 2 - American Fastbacks® - Patriot Grill
The grille is designed in the same style as the hood and looks simply awesome with it's mean unibrow. Except for the visual appeal it also improves the air dynamics and lets more airflow into your engine.
View prices and more details on the Grille here: American Fastbacks® - Patriot Grill
Both products are designed to be used together, although they fit nicely in the exterior of JK even if installed separately. Read more about American Fastbacks here.
What do you thing about the Grille and the Hood?
Would you take both?
Vendor
Hi everyone,
I was checking the updates on new Wrangler products and found this awesome steel Dome style hood with functional air vents.
It has and aggressive, yest simple design and durable steel construction. Amerihood brand is famous for their high quality fiberglass and steel hoods. The hood installs with a help of original mounting hardware and comes unpainted.
  • Good for 2007-2015 models
  • Galvanneal Steel Just Like OEM
  • Functional Heat Extraction Vents With ABS Plastic Bezels
  • Utilized Factory Hinges and Latch
  • E-Coating For Rust Resistant.
  • 07-12 JK Requires additional Squirt and water hose, which can be obtained from Jeep Dealership
Additional Jeep OE parts needed for 2007-2012 model:
Washer Nozzles: 68164356AB
Washer Hose-Front: 55078127AG
Hood Bumper: 68192987AA
Windshield Hold Bracket: 55176422
Parts Number is for reference only. Please double check with your local dealership for the accuracy as manufacture do update their part number on newer editions.
How do you like this hood?
